How can I tell what engine I have???
sebas54
I can't find the serial #'s and need to know what engine I have. I know it is a 1987 gm 175hp 4.3l
In my manual there is mcm model number 175 alpa/mr and 4.3l alpha/mr How can I tell which one I have. the only difference that I see is that the max WOT is different.
Thanks!!
Don S
Re: How can I tell what engine I have???
Do you have a serial number tag over the starter?
sebas54
I replaced the starter last year with a new one. I will check the engine #'s tomorrow.
Don,
I need to know this because I am only achieving 4000rpms with 18" pitch prop. I was told that this was under powering it but if I have the 175/alpha model then I would be within my recommended rpms(3800-4200).
Thanks
o-jay
Mine's an OMC, but it sounds like your manual is describing the same thing by two different names.
I have a 4.3L GM v6, and it's 175 hp. Like I said, mine's an OMC, but I think your manual's reference to 'alpha' is the Mercruiser Alpha One outdrive.
I'm kind of talking in circles, what I'm saying is it sounds like your engine is a 4.3 L GM V6 that is rated 175 hp, in front of an Alpha outrdrive.
Ayuh,... Is it a 2bbl. or 4bbl. Carb,..??
Don S
The reason he is trying to find out what engine he has is because of how Merc designates the engine by model number. In 87 it was called a 175, in 88 it changed to 4.3L. Which one it is, depends on the SN, not the drive or anything else.
attachment.php
