dolluper
- Jul 19, 2004
- 3,911
Re: Horn Problem on Daughter's car? PROBLEM SOLVED 10/2/05
Yes Boom the one at the bottom of your pic 2 together on the left and the LONE ONE ON THE RIGHT [horn relay] if you jump it and the fuse blows that's good .Replace fuse and relay<br />JUMP "D" pins <br />L-O-N-G way<br />Test light<br />A to ground<br />B to ground <br />no light short in C<br />.......<br />Light on for A + B test<br />Test light between A + D press horn<br />light comes on brack probe B to ground with relay installed,press horn,lights bad connection at B or short from B to horns,,no light replace horn relay<br />this A+D test no light Pressing horn bad connection at B or horn relay<br />check
