Honda 50 hp stull when passing from R to N
Sylva-Ranger
Honda 50 hp 2011 Programed fuel Injection S/N BBEJ-1005971
Start and run fine , good acceleration, ,run great until you shift Reverse to Neutral............ More of the time the engine stop
The engine NEVER stop if you shift from N to F or from N to R ..........NEVER stop while runing in REV or FWD ,, Can run at low or hi speeds for very long time and run good.
Sometimes stop when shift from F to N , maybee 40% or less of the times.
The engine Stop when you shift from R to N, ( more than 85% of the times) .
If you shift quickly or slowly, engine cold or hot is the same , whit the boat in the water or out of the water whit the muff is the same.
Do you have an idea ?
Do you know if theses engine have a kind of stop switch to help shifting like some stern-drive ? may be the TPS sensor ?
I tried to check whit a timing lite if ignition stop during shifting process but look ok
Thank you and excuse me for the bad english
Sylva-Ranger
Using the Honda p/n 070PZ-ZY30100 jumper there no engine code.
ahicks
Wowee, that's a challenging issue!
I haven't worked on many of these, but don't believe there is a momentary shift switch/sensor.
Idle speed seems normal? Have you tried raising the idle a little?
When it quits, is it sudden, or does it miss a few times before quitting?
When the shift is successful, same thing. Does it shift without missing a beat, or does it miss a little after the shift?
Sylva-Ranger
Idle speed seems normal, may be just a blit slow.........
When it quits, it miss a little bit before .
When the shift is successful, it sometime miss a little bit....
I tried in neutral whit le small lever, and at a certain position (just above idle) it sometime quits ..............
I haved see many time an outboard thats quits when you shift to REV ou FWD , bur never from R or FWD to N , its like if the throttle make stop at a certain position an djust in one direction.
I dont have the factory manual, but in the Seloc they show a .throttle Switch" but no way to test it or explanation .
Sylva-Ranger
Try to have the factory service manual , nearest dealer said that Honda don't sell any service manual (paper on download) to customers. You have to be a Honda dealer to have acces to the on-line service manual.......
ahicks
That's complete B.S. Wishful thinking on the part of the dealer.
Ebay often has the OEM Honda manuals listed for about half what Honda gets for them. A page or 2 might have a greasy finger print, or it might be brand new still wrapped in plastic.
Sylva-Ranger
To date, all the Honada factory manual i saw in line (paper or download) are for older model and not cover this particular EFI programed Ignition
Sylva-Ranger
Daler said that he can print some page for me but i whant the complete manual.
Sylva-Ranger
ahicks
Are you trying to find a place that will sell you a manual?
Covid shouldn't have anything to do with that when dealing with most companies.
