Hona BF75 (7.5hp) water pump clogged?
imstevo_g
I have a BF75 (7.5 hp) and I think I sucked some mud up into the water pump. I saw the prop kick up mud and then about 10 minutes later I noticed that the water was just dripping out of the water outlet port. Is there a thermostat? Should there be water coming out of the port all the time? If it is clogged what it the best way to unclog it. Thanks
sea_stork
Re: Hona BF75 (7.5hp) water pump clogged?
You might try backflushing it, could be a wad of mud or crud clogging a bottleneck in the passages. I have used a plastic broom bristle to unclog mine. Seems to clog at the outlet where the pee tube connects to the engine.
