holes prop
Silvertip
Honorary Supreme Mariner
Re: holes prop
Their called vents. The prop would be referred to as a vented prop. The holes allow a little exhaust gas to get behind the prop blades so the engine revs a little bit quicker getting you on plane faster. They do not affect high speed performance.
gatorred
Re: holes prop
so if i had exhaust in prop area it's good because planner plate's did that from engine,it made the boat come out of water just on prop is this right yes my prop has vent hole's too.
heatz1express
Re: holes prop
I've been thinking about those holes around the prop housing too. I read something over on marinemechanic.com about drilling them yourself to improve holeshot. Charging batteries for cordless drill right now! lol If we are lucky, someone with experience in this area will reply with detail.
tommays
Re: holes prop
<br /><br />it worked for me but start small i was good with a 1/4" <br /><br /><br />tommays
walleyehed
Re: holes prop
Size of hole will be determined by the hull-type, weight, and available HP...I would highly recommend you start with 1/8" holes and test...1/32" can make a big difference, so enlarge slowly.
Texasmark
Re: holes prop
Hey guys,<br /><br />Got a problem with this diagram. The hole is behind the blade. Needs to be in front of the blade. Idea is to blow exhaust gas across face of blade to deliberately cause cavitation; hence get engine to max rpm, hence hp at max, then as boat accelerates, water from forward motion forces exhaust out the rear of hub and hole becomes useless....which is what you want.....like shifting gears....sounds like it (and feels like it) too when it does it.<br /><br />Dunno about 1/4 inch, but my Merc prop had like 3/8 holes in it. Worked great getting a lard *** (boat) on plane rapidly....or getting a skiier up fast (behind a lard *** boat).<br /><br />My 2c,<br /><br />Mark
Dhadley
Re: holes prop
The diagram is correct.<br /><br />Holes placed on the other side of the blades are for a whole different purpose. <br /><br />As for the vent holes -- as the prop turns clockwise, exhaust escapes out and is caught by the next blade.
Texasmark
Re: holes prop
Well D, it has been awhile since I looked at it (sold it about 10 years ago). Maybe they were in the same place as the diagram and I just forgot. Grin.<br /><br />Now I know what it is; that's an OMC prop and mine was a Merc.....Ha! (Little brand loyalty here. Grin)<br /><br />Mark
moderator1
Re: holes prop
I run a Merc Tempest and all Merc props vented by hole or PVS system, are vented behind the blade.
Texasmark
Re: holes prop
Yeah, I was just over looking at Merc props and I agree. I think my old vented prop was a Rapture and they are where you say they are...according to the picture. <br /><br />Oh well. Your mind is the first thing to go...I think.<br /><br />Mark
imported_bjs
Re: holes prop
i seen a prop a guy got from a prop shop and he put holes behind the holes that were already in the prop.
