I have a Mercury 60 outboard on my 16' Sleekcraft. I noticed that the voltage meter on the dash marked the correct 12V when starting the engine, but when throttle is increased the meter gradually reads up to 15V. Besides powering the engine the 12V battery has a single power line (fused) which feeds a 7amp stereo and the VHF. When anchored (with engine switched off), the voltage reads 12V and the radios work fine. But when I tried to switch on the VHF while cruising it showed a "Hi-Voltage" warning beep and I turned it off as a precaution. Could it be that the power line feeding the radios is interfering with the voltage distribution, or could it be an engine problem (eg. alternator)??
