High Voltage 1996 50 HP Bigfoot Four Stroke
aswetich
My volt meter needle has always been strait up. (Middle Of Gauge) This year it is always in the high range (Think it says over 15 Volts) that is denoted by a crosshatch pattern on the gauge face. She starts and appears to run fine but I just don't want to get stuck. I will check all the cables and connections but wanted to know if a bad battery would give these symptoms. If not what else should I check ?
Thanks
