pvanv
- Apr 20, 2008
- 6,584
Last season, I installed a new Nissan 9.8 on my 8,000-pound, 28-foot sailboat. I also installed the 5" pitch x 8.75" diameter, 4-blade HT Solas/Tohatsu prop. The tachometer showed that I was turning max RPM's in excess of 6,000, maybe up to 6,200 -- just below the rev limiter point. The correct WOT range for that motor is 5,000 to 6,000.
This season, I changed to the 7" pitch version of the Solas/Tohatsu HT prop, to lower the max RPM's, and possibly gain half a knot (hoping to push the heavy displacement boat to hull speed -- 5, maybe 6 knots). As expected, it did knock the WOT RPM's down, with a slight increase in boat speed. What's surprising is how MUCH it slowed the motor down. Now the tach only makes it up to barely 4,900 or 5,000 at WOT.
So that old rule of thumb for changing pitch and how it relates to RPM is not correct when using 4-blade HT props. A 2" pitch change resulted in a 1200 RPM change. Apparently, my ideal pitch will be 6", which is not a stock, off-the-shelf prop.
