high pitched ignition beep
Ramblin'man
1995 bayliner capri 2050ls
When the key is in the ignition and it is turned to the on position, that awful bayliner high pitched beep noise rattles the ear drums until the engine is started. Any idea where the contraption is that produces this noise is located and the best way to bypass (or remove) it? It drives my wife crazy!
Rocky_Road
Re: high pitched ignition beep
It is usually under the helm near the fuse panel...but that "awful" noise is your protection while the engine is running. The engine alarm system can save you an engine (or outdrive) rebuild!
Dave.Mishchenko
If you place some tape over the hole the alarm is still audible but less painful to hear.
Ramblin'man
So by not having the alarm,what could cause the damage and rebuilds? Startled and curious both. Thanks for the info, help and pics guys. Iboats is the best
Dave.Mishchenko
The alarm will go off for items like low engine oil, low oil pressure, overheating engine, low drive oil, etc. It's like the check engine light on a vehicle. When it goes off it's best to stop and figure out what's wrong before some serious damage can occur.
Rocky_Road
I personally was saved from engine damage by my alarm: I was navigating down a narrow (and shallow) channel with a very small room for error defined by the channel buoys. My total focus was on the channel markers and my depth finder, when my alarm sounded. I shut her down and found a plastic grocery bag 'snagged' on the leading edge of the outdrive, and blocking the inlets for the water pump. My temperature overheat alarm is set for 190, so I had no damage. Without my alarm I would have probably never noticed the temp gauge on the rise....
Happy boating!
