jeremy5780
Thread starter- Joined
- May 8, 2008
- 147
I have a 1990 200 johnson VRO new to me. I test ran it with the guy when I bought it Very quick run due to weather ran fine other than rough idle. Took it out two weeks ago when I got it home still idle was rough was slow to get on a plane and would surge at WOT. Took it home cleaned carbs (not dirty and all needls and float levels look fine) and replaced fuel line. Took back out and did the same thing again, and started sneezing at idle. Brought back home and checked spark, good blue spark on all cylinders. Dont have a tool to check spark length. Noticed fuel line was a little big as it was sucking a little air around the t fittings so I got smaller line and rebuilt the vro fuel pump (oil is disconnected) Checked pulse line, strong pulse when motor is cranked. Also cranked engine and fuel pump has good output. Sneeze quit with the smaller fuel llines no air. replaced primer ball and took out the inline glass fuel filter. Even ran on a small 6 gallon fuel tank to eleviate in deck fuel tank problems. Still surges at WOT. She runs smooth at 1/2 even 3/4 throttle but when you punch it to WOT it surges until the throttle is back down a little. What the hell is going on? thinking about adjusting the carb float just a hair to allow a little more fuel in. Just worried this may make it get to much fuel at idle.
