Help with prop selection Suzuki DT225
Singing Boat Guy
I finally got to run my boat and I hit 60 mph at 5400 rpms with a 24p stainless prop. My question is would I gain more speed by dropping to a 23p stainless prop and getting another 150 to 200 rpm bringing me to the top of the operating range of 5000 to 5600?
steelespike
Re: Help with prop selection Suzuki DT225
Not an expert but to me your dialed in pretty good.A drop in pitch might result in about the same speed but a little better holeshot.
You might want to fine tune your setup.At that speed a 1/4' increase in height could make a world of difference.A jack plate may give you better results than playing with the prop at this point.Once your all set up then a prop change might improve top speed.
