Hi this is my first post on here although I have read and found alot of helpful information on here.. I have just picked up a 1985 baretta runabout I dont know the model it is a 16' V-hull boat. when I got the boat the interior had been partly removed by the previous owner and there are several white hoses connected to thru hull fittings on the hull but other than the bilge none of the other ends are connected to anything.. I am hoping for some insight as to where to connect these lines.. I have found drain spouts on the 2 open bow compartments and also one in the port console Ive thrown some pictures in also. the 2nd hole in the transom does not have a thru hull fitting on it just a hole with a silicone feeling seal in the hole.. if there is more info I can give that would help ask away..
thank you very much in advance for any help
Brad
