Hey guys, great website. I’ve been doing a lot of reading and I’m very mechanically inclined but I’ve never touched a boat motor. And honestly, I’ve gotten kinda lost in the language of everything I’ve read regarding adjustments and such.
i have an 84’ 35 Johnson. I just took it out for the first time yesterday and had some carb/fuel maybe timing issues. This is what’s happening...after going into into forward gear, I have to push the throttle lever to about half throttle before the throttle actually begins to open on the carb. Then, with the lever at wot, the butterfly is only half open. It will run briefly, then die, as if it ran out of fuel. I assume there are throttle adjustment and maybe timing issues going on here.
Can someone help me reset the linkage if that is in fact what the problem may be?
thanks!
thanks!
