Help with 35 Johnson
smokedoff
Hey guys, great website. I’ve been doing a lot of reading and I’m very mechanically inclined but I’ve never touched a boat motor. And honestly, I’ve gotten kinda lost in the language of everything I’ve read regarding adjustments and such.
i have an 84’ 35 Johnson. I just took it out for the first time yesterday and had some carb/fuel maybe timing issues. This is what’s happening...after going into into forward gear, I have to push the throttle lever to about half throttle before the throttle actually begins to open on the carb. Then, with the lever at wot, the butterfly is only half open. It will run briefly, then die, as if it ran out of fuel. I assume there are throttle adjustment and maybe timing issues going on here.
Can someone help me reset the linkage if that is in fact what the problem may be?
thanks!
jasper60103
thanks!
Considering your experience level, you might consider having a mechanic do an inspection.
jbuote
Hey there!
Well, since you want to take a stab at it, might I suggest the best thing to get now would be the factory service manual.
It outlines the "Link & Sync" procedure, as well as setting timing (if it needs to be set.. Usually not, but...)
The pro's here certainly could outline how to do it all, but perhaps having the manual would better serve for future issue as well.
Clymer and Seloc manuals are also available, but usually encompass a broader range of years, and tend to not be specific enough in places..
Factory service manuals can be found through things like ebay, but you can also get a new copy from Ken Cook at outboardbooks.com
do a search for your model number, (minus the last letter in most cases) and you'll find it..
From there, these pro's could better help guide you with question about the procedure or specs etc... should you have any, versus trying to teach you how to do it from scratch... (which some will do, if really needed... )
That was the first piece of advice I got on my first outboard, and I'll tell you...
there is NOTHING like having the factory manual! LOL
Hope it helps!
flyingscott
Look at the wire that runs from the stator to the carb could be out of adjustment.
smokedoff
I was mistaken on the year. Mine is an 82. J35elcnd. I can order a book from the place mentioned, but if I found an oem manual, say on eBay, what other years would work? Or would it need to be specific to 82?
jimmbo
Year specific is safest as the are often minor differences(linkages, ignition and fuel systems, lower units) throughout an engines production lifetime. The 35 hp was one of those. Using the incorrect yr of manual is basically the same as using one of the generic covers-them-all aftermarket manuals
jakedaawg
Check to make sure the throttle cables is not broken/stretched. 1st step.
did it ever run good for you or is this boat/motor new to you?
smokedoff
New to me, just ran it the other evening for the first time. it cranks right up and idles, but beyond idle it has issues. The console lever has to be where “half throttle” should be to get it off idle, then at what would be wide open, the butterfly is only 40% open or so. It’ll run like this and then the motor dies. It’ll fire right back up and idle afterwards.
i looked at it last night some and decided to pull the carb, went through it today. It was clean and looked good but I put a rebuild kit in it anyway. It had recently been into. It also has a new fuel pump and starter solenoid. From what I read and watch, it has linkage/timing issues. I think the previous owner couldn’t figure this out so they just threw parts at it...then sold it off.
Willyclay
I have a 1985 Johnson 25hp that is almost exactly like your motor. It displayed similar linkage issues you described when I first got it. I found a "spring" was disconnected on the top of the "control lever" which are part numbers 81 and 37, respectively, in the BRP/Johnson parts catalog at the link below. Good luck!
http://shop2.evinrude.com/Index.aspx..._id=0&siteid=1
EDIT: You have to drill down to the "Cylinder & Crankcase" page for these part numbers.
jakedaawg
Get a manual. Easier than typing in 12 pages of insructions. Some find them online at boatinfo or someplace. Do the link.and synch.
before spending any money though do a compression test and post results. Someone had their fingers in it for some reason to mess the linkage up. Compression test will determine if it's worth spending time with.
most auto parts stores will loan or rent a decent guage. Don't bother with a harbor freight chinesium one.
smokedoff
I will try to get a compression test done tomorrow and I’ll check on a manual. I glanced at it this evening for a sec and the spring you are referring to willyclay is intact on my motor.
To better describe what is happening, the shifter cable is “responding” or “moving with” the console throttle lever. So the breakdown is after the throttle cable (although it may need adjusting at the end).
So as the throttle lever is pushed forward, the cable responds and extends, the vertical rod on left side of motor begins to rotate. At this point, through most of the throttle range, only the magneto under the flywheel is moving/rotating with the throttle. The small horizontal rod with set screw and stop, forward to the roller, and on to the carb isn’t moving until after half throttle.
There’s a little more detail into what’s happening. I’ll get back tomorrow with compression test results and go from there. Thanks for the patience and help!
jimmbo
The throttle linkage on the engine is designed to advance spark greatly before the carb even begins to open a tiny bit. Full advance and contact with the stop with set screw on the rod should occur at the same time, then further throttle lever movement opens the carb
smokedoff
So that clears up a question I had. I do see the timing advancing before the carb is affected by throttle movement. I wasn’t sure if that was correct or not...and there still may be adjustments that need to be made.
I’m getting the starter rebuilt so I haven’t done any work on it but I’ll get back on it tomorrow.
thanks for the help
