help with 1988 johnson 9.9hp
thads king
i can not get the motor to start think it is fuel related but not sure i don't know how to begin i could use help
boobie
Check your compression, then your spark which should jump a 1/4" open air gap and then squirt some premix fuel in the carb throat.
Vic.S
"Outboard wont start" on the Engine FAQs board will take you systematically through the checks to do
Other FAQs will tell you how to do various things
Ryan0186
First thing I would do is take the carb off and rebuild it. Then check that the fuel pump is in working order. An easy test to disagnose fuel pump is to have someone continue to prime the engine with the fuel bulb and start it. If it will run from priming but stops once you stop priming then its a bad fuel pump. These fuel pumps can be taken apart and cleaned/rebuilt with a kit but be very careful to orient the parts back in place correctly. If the orientation is wrong in any way the pump will not work. Also like many of the previous posters said check spark plug and gap. These little engines are bulletproof. On the several of them I have owned over the years it has 9 times out of 10 been a dirty carb.
thads king
okay i added fuel down the carbuartor and started replaced fuel pump have fuel at the carbuartor but will not start on it sown
