HELP::: Water pump in Johnson 150 GT V6
Jburgoon
Could someone please help me? I'm trying to change the water pump in my Johnson and I can't quite figure it out. I've gotten all of the bolts out of the foot, but I cant get it to slide all the way out. It seems like it is catching on something.
wyngo
Re: HELP::: Water pump in Johnson 150 GT V6
under the bottom carb is the shift linkage. the screw holding it must be removed, and then the lower unit should drop down.
