royal0014
Master Chief Petty Officer
Thread starter- Joined
- May 6, 2010
- 874
RK-28B, 1966 Johnson 40hp Electramatic
Ye Ol Johnny left me stranded this morning. Hope someone here can help shed some light
Last year I had the same thing happen twice. Carb would flood out, spit gas out of the hole beside the low-speed needle, and around the butterfly. 1st time I just pulled the plug on the bowl and drained the gas out, and she ran fine after. 2nd time I tried the drain trick three times and it would flood again quick. Both times were cold starts, still on the trailer.
So, this spring I rebuild another carb that I bought off flea-bay. Same exact carb, though it was supposed to be off a '68 40hp. Full rebuild kit, gaskets, float, needle/seat, etc. I reused the l/s needle cause it was fine. Because of my job, the boat has sat all summer (today was only the 3rd time out). The other 2 times out it ran good. An occasional sneeze, but minor....
And today, she cranks up and idles no problem. Start out and run about 3/4 of a mile at less than half throttle to where I want to fish. She hiccuped a little a couple times, but kept going. I shut her down and fish about 2 hours. When I decided to move across the river, she fires right up. I'm only going about 1/2 mile, so I ease along, and she starts cutting out. Just a quick bog down, like it's running out of gas. I check the bulb, it is firm. Does this 3 or 4 times, each time picking back up, but running a little worse. I try varying the throttle more or less (still under 1/2), doesn't seem to help. Finally she dies all together. As I 'm trying to restart I open the hatch and see the gas coming out of the hole. Flooded on the run
I try the drain-gas routine 3 times. Each time it would crank and run for about 3 seconds and flood out. I give up, and use the trolling motor to go the mile back to the ramp.
So, any ideas? Two carbs, same problem. New fuel line when I put on the rebuilt second carb. I'm thinking trash on the needle, or sticking float. Maybe if I had tapped on the bowl the float would have unstuck itself?
Thanks for the ear guys. Sorry for the long post, but trust me, it'll take you an hour less to read it than it did for me to write it :facepalm:
