rwaterbury
Thread starter- Joined
- Jul 29, 2006
- 9
I've got a Volvo Penta I/O 5.7L engine with a temp sensor that is always reading <100 F by the gage and I doubt that the engine is reading this cool. When I measure the resistance of the sensor it is 550 ohm at room temp. Does anybody know if this is normal for this type of sensor. Also the voltage on the temp sensor wire is only 0.2V, it seems like this would be a higher voltage to get an accurate reading.
When I short the temp sensor wire to the engine block (ground) the gage does not change. Is it possible that the instrument panel ground wire is not connected? However all other gages do work.
