HELP! Trim relay/electrical malfunction.
Tayfarm
I'll try and keep this short, lots to talk about. Rinker 262 w/ Volvo 5.7 GXI-F. Last time I had my boat on the water the trim/tilt worked great. That was 2 weeks ago. A few days ago, I backed the boat in the water and went to tilt down...nothing. Both relays are clicking when I press up and down. Motor and pump are fine, I jumped a wire from the battery, works up and down. Removed one of the relays, had become hot sometime, and slightly melted the plastic casing. Got two new relays, still clicks. Cleaned connections with contact cleaner and really wiggled relay wire and connections. (tough to move as the harness is riveted to the motor bracket) After i wiggled with them for a couple minutes, I hit my trim button again....it worked, for a second, then clicking again. Well it is definitely electric. Corrosion, bad connections, etc. And get this, I was doing this practically in the dark and had most of the boat cover on and when I pressed the trim button down i could see the cockpit led lights have a very faint flicker. Would not be able to see this in the daylight. Very odd. Any suggestions???
Re: HELP! Trim relay/electrical malfunction.
Ayuh,.... Welcome Aboard,.... Use paragraphs...
You have dirty corroded wiring,... The only Fix, is take it apart, 'n Clean it....
Start at the battery terminals,... Clean shiny metal, at all connections...
'n don't forget the Grounds....
Tayfarm
Thanks. I will check out the wiring. The battery terminals are in very good shape and not corroded. The only thing I can think of is the wiring that comes into the relays may be corroded. Any other suggestions? Does a 2005 Volvo GXI have a 50 amp breaker? I could not locate it.
Texasmark
Most wiring is protected by fuses in marine and other applications. Exception is starting circuit. It's a fire safety thing.
Mark
