Jackblack747
Thread starter- Joined
- Sep 2, 2008
- 2
Hope someone can help diagnose this late season engine problem. Don't know what might be important, so I'll just put in all the facts.
This is a 90hp Mariner outboard.
At the start of the season I noticed fuel mixture was being sprayed on the inside of the engine cowling (hood). I traced the problem to a fuel line low on the right side of the motor (as you face it from the stern). The rubber hose was cracked/ worn, and the fuel mixture was spraying out. I replaced the rubber tubing, and ever since then, the engine worked great all summer....until last night.
Just after sunset on the way in, we stopped to help a boat in distress. They had a dead battery and jumper cables. I undid the cables from my battery, and they started their boat with my battery (it took only 1 turn of the key for them to start). I then, put my cables back on my battery and went to continue in, but the engine would not start.
At first it would only crank, but soon (and now) cranks and 'does start', but only for 1 second or 2, and then kicks off. I mean, the engine cranks, catches, the oil beep, and water exhaust come on, then it quits, it never really gets going.
I tried reapplying the battery cables. Made sure there's gas going from the external tank to the engine, checked the 1 fuel line I replaced months ago...all are ok.
The primer bulb gets firm as usual. All the lights, stereo etc. work, and the engine does crank normally, and catch, but only for a second.
Any ideas on what it could be?
On what I should check next?
Was the whole incident with undoing the battery cables, and jumping the other boat, just coinidental, as seems likely?
Anyway, I spent one cold night stranded on the lake and just got back today.
All ideas welcome...........................
