Help restoring badly oxidized bass boat flake finish.
jbcurt00
Re: Help restoring badly oxidized bass boat flake finish.
The link you posted: Pictures of How to Restore Like New Color & Shine to Faded Fiberglass Gelcoat
Has good info if their product works as well for the DIY restos most of us are working on, but the problem is you're looking to get similar results from a metal flake that was applied IN clear gelcoat, not solid color gelcoat like all their pix:
BEFORE
AFTER
As has been mentioned, if you can FEEL the metal flakes, they are sticking UP OUT of the gelcoat they were originally IN.
Getting familiar w/ terms & products used on boats will help greatly. I suspect that you 'hear' or read clear coat & think paint. Unfortunately, boats aren't typically painted w/ clear coat. When they get painted, they are usually painted w/ a color. If for some reason a painted boat 'needs' to have a coat of clear laid over the paint, it's usually referred to as clear coat. Many clear coats are an automotive clear coat. And although it's designed to be exposed to the elements, you don't usually leave your car IN the water for possibly long periods of time.
Boat metal flake isn't remotely similar to automotive metal flake, and is usually a MUCH larger flake then is typically found on autos/trucks & etc.
Gelcoat is sprayable but it is not paint, and it's remotely not paint-like.
If Bond-O appeared abrupt, I doubt it was to be combative.
IMHO: As a moderator of this forum, he can be an invaluable resource on any resto~project. Having him hang around your boathouse while you work on your boat and be available to lend advice, is a good thing.
Yacht Dr is also a great resource to have checking in & offering his assistance on your project, esp w/ gelcoat questions
CheckmateEnticer
My old Checkmates metal flake looked alot like yours or maybe even worse. It was clearcoated in the past and starting to peel when I bought it and peeled more as time went on. Having experience with automotive paint, I started sanding off the cleer so I could buff the gel on the boat. I had no gelcoat experience at the time so was leary of using any strippers or solvents to remove the clear. After alot of elbow grease and research i came across a citrus based stripper that turned out to be safe for gelcoat and used it to easily remove the remaining clear. I started by wet sanding with 1200 grit paper to smooth the finish before buffing. That was a pain in the *** so I tried buffing with a wool pad and a course cutting compound without sanding at all. Eurika! The results were just as good without all of the labor. I then buffed with a polish/swirl remover and a foam pad followed with a quick coat of wax. I am very pleased with the results and so far a year later the finish hasn't dulled much if at all. I could throw another coat of wax on to shine it up a little but why bother. Granted, my boat is stored indoors at all times but does get used 2-4X per week from April through October. In my opinion, gelcoat, is very forgiving versus automotive finishes.
wolfsmurf
Sent you a pm
