HittinSteel
Thread starter- Joined
- May 10, 2010
- 22
I purchased a used Lowe 24' pontoon boat last spring. The seller had replaced the flooring at some point with what he said was marine grade plywood. Instead of carpet, he used a vinyl flooring. Only problem is he did not properly get the vinyl flooring to the edge of the plywood in a few spots and therefore an inch or so of the outside wood is exposed to the elements.
In these spots, water has been sitting obviously and I can start to see it is weakening the wood.
Is there anything I can do at this point to stop the slow rot before it becomes a problem?
Epoxy? Some type of sealant?
Thank you,
Bryan
Thank you,
Bryan
