Help please on gas to oli ratio
crispty
Hi can anyone help me out? I just bought a 1991 Starcraft Starfish 200 with a 70 hp Force outboard motor. I am not sure on the gasoline to oil ratio for this. Any help would be great.
Thanks.
WillyBWright
Re: Help please on gas to oli ratio
Welcome to iboats. :)
50:1 which is one pint to 6 gallons for all Forces.
crispty
Re: Help please on gas to oil ratio
Thanks so much for your help. I thought it was 50:1 but just wasn't sure.
sdunt
The greatest thing EVER invented for this is a mix bottle: http://www.iboats.com/2_Cycle_Oil_M...d.246639--list_time.1181749579--view_id.56142
These are CHEAP and I used a marker to label the 50 to 1 mix for my six gallon tanks. If you have builtin tanks, just read how many gallons you put in at the pump, measure out oil to that line and dump it in.
TO make sure you ALWAYS have oil in the fuel, Add the oil as soon as you add the gas. The aggitation on the drive home mixes it up real well.
