Johni1cars
- Sep 5, 2022
- 24
Thanks in advance to anyone that can help me out. Its a 1988 johnson outboard with 200hrs on it. I've own it for 7 years. Motor has been amazing. Best toy I have ever owned. Ran perfectly until this year. I decided to do the water pump impeller this spring bc It's never been done. Motor not the same since. Put it in the lake. Starts up fine, after driving for few minutes stalls. Pump primer was soft pumped up and starts up again. Same thing. Thought I had a bad tank. Switched tanks. Next time I went out same thing .. stalling after a few minutes out on the water...next time I went out changed primer bulb and fuel line. Same stalling issues. Fuel filter replaced with a clear wix fuel filter. Noticed that the filter was emptying out. I felt that the carbs were starving for fuel. Everyone I spoke to said the vro pumps on these motors are bad news. To be honest I love this vro system...works perfectly. So I did the vro delete and put on a cheap Amazon pump on the side of the block. Premixed my oil and gas...It might be a touch rich...like 50ml...it's a 23 liter tank. Since then the motor runs better when choked...fuel inrichment on. It won't hold an idle. Rebuilt carbs. Compression is 150 top and 145 bottom. Checked spark. Seems good...it's loud and when I disconnect a cylinder engine stalls. Checked resistance of coils... 245 each. I tried playing with mechanical timing adjustment. No luck. On my last try out on the lake I noticed the motor ran better. Still won't hold an idle with throttle closed in neutral and lack of power doesn't seem to stall any more while driving....power pack? Bad fuel pump? Thermostat? Or did I screw something up when changing the impeller and taking lower unit off. Please help.
