buzzkillin
Thread starter- Joined
- Jun 27, 2011
- 7
140 HP v4 Evinrude (older model - 80's) 2 stroke.
17' Starcraft Bass Boat
Just bought the above boat and motor from a guy who used it pretty regularly in tournaments. Took it with him for a water test. I was with him from the time he dropped it into the water. Boat has a hotfoot setup. Engine started up on the 2nd try and the owner was the one starting it. Owner let it idle in neutral revving it a bit to warm it up for about 2 minutes then went out on the canal at about 8 kmh on the GPS, then he really hit it and it felt like I was going to fly out of the boat. I was very impressed, nothing seemed to bog down, stall or have any issues. Everything went well, so I purchased the boat and left it in the slip at the marina we met at. The next morning I went out and try to start it up but couldn't get any pressure inside the gas bubble. Being a noob a still tried for about 30 seconds to get the engine to start - to no avail. Then used the trolling motor and headed over to the marina gas bar and filled up.
Engine then started up with no real issues, but wasn't holding the idle very well. Revved it a bit in neutral to warm it up and then headed out. Left the canal with the engine trimmed all of the way in and as soon as I hit about 9 kmh the engine would cut out. By cut out I mean it was like it turned right off. Put it back in neutral, turned it on again, got up to about the same speed (on GPS) and engine cut out again. Tried a few more times and the same issue. I fished for a bit (an hour or so) tried again but same issue, so I headed back in - boat didn't stall, or cut out on the way back because I kept it at the constant speed of about 7KMH.
Does anyone know what the issues could be?
The boat and motor did go to a Marina prior to sale for a one over. they replaced a fuel line, other then that everything was in good working order. On the water test the the day before yesterday it did fine.
Any help is appreciated. BTW the previous owner and I are still in contact. I am confident that he has been truthful about everything and is willing next weekend to come back out and help out if needed.
I am new to boat ownership, so perhaps I am just missing something simple?
