Help needed... Wiring harness for Mercury 2004 40 HP ELPTO
Johnfromflorida
Hello! I just purchased a 2004 40HP Mercury ELPTO outboard. I have yet to receive the motor as it is being shipped. I need a little help if someone would be so kind...<br /><br />FYI, I will be using non Merc controls with a seperate ignition switch.<br /><br />I located a new OEM Mercury outboard wiring harness with the ignition switch but not sure if it is the correct harness for my application. The harness has a male end with 8 prongs on the end of it. The other end of the harnes has a white female plastic rectangular plug that plugs into the ignition switch. <br /><br />QUESTION 1. Will this work with the 2004 Merc 40hp ELPTO?<br /><br />QUESTION 2. Does the outboard itself come from Mercury with the female receiving end of the harness or will I need to get this too?<br /><br />QUESTION 3. The ignition switch has 5 blades with the letters S, C, A, M, M, B, by the blades. There are two, open connection, yellow wires, one with a red stripe comming off of the S blade on the ignition. Along with a plain yellow wire comming from the male plastic rectangular plug that plugs into the ignition switch. What are these Yellow wires for? <br /><br />QUESTION 4. Also, there are two black wires comming of the ignition swith with the letter M by them. What are these for? <br /><br />I can take pictures and email them to you if it helps to better understand. A picture is worth a thousand words. Email me at fastervw@msn.com <br /><br />I appreciate your help!!!!!!!!!!!!!! :)
