Help Needed From 383 Stroker guys (Starter Issue)
Flysfloatsor
Banned
Since I changed from a 12" flywheel to a 14" for externally balanced 400 rotating assembly, I cant find a starter for it.
1. 168 tooth 14" 400ci SBC flywheel
2. Straight bolt hole pattern starter.
3. Alpha bellhousing.
Anyone have a part number for me? from NAPA Preferably?:)
Flysfloatsor
Banned
Re: Help Needed From 383 Stroker guys (Starter Issue)
After searching the internet for 3 hours, Im thinking the unspeakable has to be done... Use an auto part :(
RogersJetboat454
And thats your problem. The 168 tooth flywheel uses a cross bolted starter. I assume your block was not drilled for a cross bolted starter?
They call this a marine starter;
http://www.summitracing.com/parts/TIL-54-20201/ View attachment 94350
At the price of $454 dollars I believe them too. It will work with a strait bolt setup on either a 153 or 168 tooth flywheel.
Don't know if you may have any interference issues with your flywheel cover though.
Good luck!
Ayuh,.... Your block Don't have the 3rd starter mounting hole,..??
The Flywheel diameter determines which starter has to be used, not the other way 'round....
The Hot Rod starter Rogers posted will probably work...
Fit it outside the boat so you can See, 'n Measure things...
Btw,... What part of my signature don't you understand,..?? :(
Flysfloatsor
Banned
Bondo: Just read it, no worries - wont contact you again.
Thanks for the input Gents.
