Help need to wire new fish finder
ccm14
Hi,
I had a Lowrance X102C fish finder on the bow of my bay boat that died so I purchased a Lowrance X-4 unit to replace it. The X-4 has two wires, one black and one red. The old unit had 3 wires. One larger wire and two smaller wires. I have been told that the larger wire is for networking purposes (which I never used). When I cut the original connection off to wire in the new unit this is what I found:
Larger wire...it contained 3 small wires colored red, black and white.
1st smaller wire...it contained 3 small wires colored red, black and one
wire that was naked (did not have any covering).
2nd smaller wire...it contained 4 wires colored blue, orange, yellow and
one naked.
I will also mention that the wires contained in the smaller wires are very small wires.
I need advice on which of these original wires that I should connect the red and black wires from my new unit.
I appreciate any advice you can offer.
Boss Hawg
Re: Help need to wire new fish finder
I'll give you a bump so Silvertip mite see this- He's your best hope--
Hi,
one naked.
Ayuh,.... 'n All ya need for the new unit is (+), 'n (-),..??
Then with a test light, SEE which is battery power, 'n which is battery ground....
ccm14
That got it.
Thanks for the help.
NYBo
I would run new 16 gauge wire from the fuse block to the bow rather than relying on the existing harness.
