HELP my johnson 110 driving me nuts
mauiboy
HELP anyone <br />Let me tell you what my problem is when the motor is cold it starts and runs fine after it warms up it seems to flood from the carbs I tryed sparying carb cleaner but it do not help.<br />anyone with ideas. :confused:
rwcreigh1
Re: HELP my johnson 110 driving me nuts
tear them down and clean them.are you sure it is not overheating?a manual will help.good luck
mauiboy
Thanks richard 1 but the carbs waas rebuilt 1 week ago and it is not over heating. do you or any one know if it could be the carb adjustment?
Does the primer bulb get firm when squeezed (before starting the engine)? If it doesn't, the float level in one or more of the carbs is misadjusted which prevents the inlet needle and seat from closing off the flow of fuel. You also did not indicate year and/or model number of your engine. Spraying carb cleaner in the throat cleans only the throat -- it does absolutely nothing for the internal carb passages.
mauiboy
Yes Upinsmoke the Primer bulb gets hard<br />my 110 is a 1987 forgot the modle on it and it dose bak fire from the exaust also it seems only when the motor gets warm it floods? :confused: :confused: :confused:
Dhadley
If it backfires thru the exhaust, its not running fine. If it is indeed backfiring thru the exhaust there are wires crossed somewhere or one cylinder is not firing and when the raw fuel gets in the exhaust its igniting.
mauiboy
Thanks Dhadley<br />Can you tell me how to check it out or how to check the system with out spending a lot of cash.
Dhadley
Probably. But first we need to know exactly what its doing or not doing that needs changing. Is it indeed backfiring thru the exhaust?
mauiboy
Ok Let me tell you whats going on with this darn thing. in the morning it starts good with the help of the fast idle how ever I hear what sounds like it is missing. then i head out to my fissing hole and fish for awhile. Then I pull up and move when I stop the motor dies and wont start. When I look I can see gas film all in the water I know it is comming from the carb the lower one. I hope this will help you determine what going on.
sikpnter
Who rebuilt your carbs?
mauiboy
Ok guys I restarted the motor and now it sounds like it is comming from the carbs but sounds like it is also comming thur the exhaust. I am not a real good at this but I am able to fix things with the help of others like yourself. When i start the motor I have to put the idle leaver up all the way then bring it down even after it warms up. I thing it is some thing to do with the carb adjustment. can someone tell me how to do this?
Walker
I'm with Richard. tear the carbs down and clean them again. Don't use spray cleaner. Get some soaking type and soak them for a couple of hours and then blow out each and every orifice and passageway with compressed air. Double check the float setting and put them back together.
