reelfishin
Thread starter- Joined
- Mar 19, 2007
- 3,050
I happened upon two reels this week, one reads Thunder Bay LD30, and is about the size of a Daiwa Sealine 30H but with graphite sides and lever drag, it resembles an Okuma Catalina but is made from a solid billet, uses all US threaded stainless hardware, (a magnet wouldn't stick to any part in the reel), and uses 2 1/2" diameter 7 disc drag. It's a lever drag reel, not a casting reel and has two harness tabs on top. The ratio is 4.3:1
I at first bought it thinking it would be handy to have, not thinking it was anything worth much, but after opening this up and seeing the size of the internals, my opinion of it changed. The drag looks like it would stop a truck, the drag washer look a lot like the carbontex drags and are huge in size. The drag assembly is also built into an assembly retained by a circlip making assembly a breeze. If it's China built, its one of the best I've seen yet.
I've got one that reads Thunder Bay LD30, and another with no name, which is larger, just slightly smaller than a Penn 9/0 senator, that has only an LD80 badge on the left side. This reel has a much longer handle with two more handle positions, with the longest position making the handle long enough for Rock Cod use.
This reel reads 4.8:1 on the side.
I realize these are a bit large for catfishing, (the 30 size one would work for big blues), but I'm curious as to where they came from. Having at first just blown them off as cheap China import reels, I hadn't given them a second thought, but after taking a closer look, they look to be pretty decent. Far heavier than anything I've seen from the likes of Okuma, Tica, or any other offbrand reel. In hand, the 80 is about double the size of the 30. I doun't doubt their imports of some kind but by who and from where? Most odd brand reels usually turn out to be made by one of the larger brands, but I really don't see any particular similarities between these and any other known reel.
Has anyone else here seen or have any info on these? I found these in NJ, I am wondering if maybe they were more a regional sold reel?
A web search turned up nothing.
Here's a few pics, (the pics are large so I just posted them to the web, I wasn't sure how to downsize pics for here?)
LD30
http://i44.tinypic.com/29zar4.jpg
http://i44.tinypic.com/25rdqxc.jpg
LD80
http://i40.tinypic.com/90oxnb.jpg
http://i39.tinypic.com/2re4k0i.jpg
LD30
LD80
