Help identifying prop
jchopy
I just bought my first boat and am trying to determine the picth on the prop.
I measured the diameter 13" the only thing I can see stamped on the prop are the #'s 3146. There are a couple dings in the prop but I'm not sure if it's right for my boat. It's an 18ft Sunbird center console with an Evinrude 88SPL. Currently it's seams slugish at low rpm and seems tough to plane. Being new I'm not exactly sure what to expect. When it does plane it runs about 4100rpm. I just ordered the manual so I'm not sure what the WOT should be. Any suggestions on what the prop may be or a recommendation would be great.
Thanks
usskydvr
Re: Help identifying prop
Take the prop off and look for numbers on the end of the hub or take it to a prop shop, they can tell you the pitch.
jchopy
All, set, went to a marina and they showed me where it was stamped on a washer behind the nut.
