Help identify evinrude motor. Added more pictures
ugafan83
I bought this boat as a hull and it had an evinrude motor on it that runs. The guy said he thought it was a 25 hp but did not know for sure. There are no numbers to id the horsepower. Also there is no model as the badge is not on the mount. I look at it did have a welch pin but only had the serial number not the model on it.
Can get a better picture if needed.
Thanks for the help
gm280
Re: Help identify evinrude motor
Thanks for the help
First of all welcome to iboats :welcome:
You stated that there was a welch plug with numbers on it and thought they were mere serial numbers. Well those numbers can decode what the engine is and manufacture and year as well. Post those on here and we can help with that...
Also good to here it runs. Most hand over engines don't...but don't run it until it has been gone over. Most likely it needs a new water pump impellor for starters...
bonz_d
Unable to tell from the picture._ _ _ _ Looks like it's been repainted.
ugafan83
Thanks for the welcome. I am new to outboards I have always had inboards. I will get a better picture and post the numbers on the welch plug.
ugafan83
ok so here are some more pictures and one with the welch pin
boobie
Call BRP customer service with that # and they should be able to tell you what it is. 1-262-884-5993.
ugafan83
Re: Help identify evinrude motor. Added more pictures
Thanks I will try them tomorrow!
boobie
I've always had good luck with them. They have some good guys up there.
ugafan83
Thanks for the help. I call them and turns out it is a Johnson 30 horse. I guess the guy decided he wanted to put evinrude decals on it.
based on the exhaust housing it is 1989 or newer.------Many different cowlings will fit it.
bonz_d
It's good that you now know what you have. Did they give you a year?
ugafan83
yeah they did. Its a 93
boobie
Next time you post anything on it, be sure to put that in your post.
