Hi all, I recently purchased an enging and outdrive for my boat to rebuild and I can't find any info on either. They came out of a Hydroswift boat(unsure of year) and the only #'s I can find on the engine say GM model# cue 16c serial # w91391 the block# is 3915983 and it has duel motorcraft(Ford on Gm motor?)carbs. The outdrive only has #'s 382229 and 382158 120-155HP on it, does not say if Merc or omc or? it is white and on top only says outboard marine. Any help would be greatly appriciated so I can buy the overhaul kits for both.
