help i need reed valves for 96 75hp force
ghostmedik1
hi there does anyone know where i can find a set of reed valves, for all 3 cylinders, for a 96 75 hp force. all i have found is the complete reed block assemblies, for over 125.00 each ouch would love to find just the reed valves
thanx
Frank Acampora
Re: help i need reed valves for 96 75hp force
For about 125 total, you canget a set of Boyeson reeds. They are plastic and will not harm the engine if it eats one. Supposedly, they also increase performance. Never having compared a set, I will reserve judgement on that.
If interested, Just google Boyeson--I think they are in Collegevill PA. (Eastern Pa.)
Older Chrysler and Force five petal reeds and vee blocks can be found used or salvaged off any 3 or 4 cylinder junker. The upside is that they tend to last longer than the stock four petal reeds and rubber vee blocks. They screw richt into the manifold with the same mounting screws. The downside is that they are not as responsive and you may need to grind a little relief for the 5 screw pattern
See My private message to you.
