Re: Help! I need a cop.
Not only will you have a warrant in Maine, but if they are a license compact state, your license will be revoked for fail to pay in all compact states. Your priveledge to drive in Maine will definately be revoked. Then you would have to pay a re-instatement fee around $125 to get your license back, and add a misdemeanor to your record of failing to comply. Not worth it.<br /><br />The RADAR uses 2 signals. 1 to tell the patrol vehicle speed, the other to tell the closing speed of the patrol vehicle and the target. The unit then subtracts the two giving a vehicle speed. It will figure closing speed or opening speed. The newer units will give speed of vehicles in the same lane as the patrol vehicle traveling the same direction. The newest and best on the market will clock up to 4 vehicles at the same time, both same lane and opposing lanes front and rear.<br /><br />To correctly operate a RADAR unit we must check the unit accuracy once a year with electronic equipment, then at the start of each shift re-check the unit with both the internal self diagnostic program and manuialy in case the self test has failed. We test it with tuning forks, it measures the vibrations and movement of the tuning forks. Also each time we clock a vehicle, we must compare the patrol speed showing with out vehicle speedometer to verify it is working. We must periodically check our speedometer with a stopwatch to make sure it is also right. <br />To top it all off we must also check the tuning forks once a year to verify accuracy. <br /><br />While clocking a car we have to get a visual estimate of speed first. This is another verification, then we must listen for the doppler tone to show definately what the target is. <br /><br />If this is not done the judge could toss the case. Most people don't know this, most officers out of lazieness won't do this. In the end most departments won't spend the money to verify calibration of everything once a year. <br /><br />Then the officers must be certified to oeprate. The older certificates like I used to possess did not expire. Newer ones expire in 2 years. If the officer has not went baqck to 24 hours of class and re-certified every 2 years then the case could be thrown out too. <br /><br />ANyway, to answer the question yes he could tell the speed as he was moving. The RADAR units have a moving and stationary mode to do this.
