seanymph4444bill
Thread starter- Joined
- Mar 11, 2014
- 12
I just changed my water pump on my 1989 Johnson 70hp. Now I can't reconnect my shift rod, what is the trick?
Thanks guys, walking away a couple times worked. Finally got my linkage reconnected.Next time I'll pay more attention to the position of the linkage rod and the shift arm when I pull the pin to release it. I used an extra-long pair of long-nosed pliers that have a bend in them to hold the shift rod In place. Then I lined up the two and pulled on shift arm to where I could put the pin back. ON to the next problem.
