help I can't reconnect my shift rod
seanymph4444bill
I just changed my water pump on my 1989 Johnson 70hp. Now I can't reconnect my shift rod, what is the trick?
boobie
Re: help I can't reconnect my shift rod
Have you got it pointed in the right direction ??
Bob_VT
I have done MANY water pumps and I hate re--connecting the shift linkages. I find it necessary to walk away a few times and swear a bit. I tend to tape the bolt to a socket and use a long extension.
I feel your frustration
jbjennings
I'm procrastinating on reinstalling my lower unit after new seals and an impeller, and plate. I'm dreading that shift linkage, too! If I come up with any handy tricks, I'll post 'em. Seems there is a better location. Why not a window in the leg like the old small ones had??
Good luck with yours,
JBJ
boobie
How did you disconnect it when you took it off ??
Campylobacter
On my 40, the cowl is only held on by 4 screws and it is a piece of cake to reconnect the shift rod with it off.
jackler
I am getting ready to do this on my 86' 60hp, the manual says to remove the starter motor before removing the lower unit to aid in reattaching the shift rod. Is this necessary, or helpful? And the motor should be in reverse?
seanymph4444bill
Thanks guys, walking away a couple times worked. Finally got my linkage reconnected.Next time I'll pay more attention to the position of the linkage rod and the shift arm when I pull the pin to release it. I used an extra-long pair of long-nosed pliers that have a bend in them to hold the shift rod In place. Then I lined up the two and pulled on shift arm to where I could put the pin back. ON to the next problem.
DargelJohn
I have a specialized tool for this purpose. It's a straightened coat hanger with a small hook at the end. Works very well to manipulate the rod end into position.
seanymph4444bill
Here's the deal, had this boat 15yrs. Nice boat with an 89 70hp. Johnson. About 7yrs ago it stopped circulating water and overheated, and the warning buzzer went off. Not having the time, money, or knowledge to fix it, it has sat for the last 7yrs. So last week I figured out the problem, changed the water pump, started it up, it ran beautifully......for about 5 mins. Then it sounded like it was trying to stall and the buzzer went off again. Getting a nice stream of water, changed plugs, changed gas, if anyone has advice it would be appreciated. Thanks
boobie
You should start a new thread on this one as you'll probably get better answers.
Bob_VT
The "other" secret is to do the water pump impeller at the same time that you rebuild the carbs....... then you have more access and everything gets done at the same time ;)
