Well, I pulled my boat out of storage and I smelled gas. I looked at the drain plug and put my hand into a puddle and smelled gas. To go back a bit, we had 10'' of wet snow and it bent my pole and the cover dropped then it got warm rained and got cold. I stopped to look at the boat to make sure it was ok and pulled some ice off the cover and brought a new pole and found ice under the engine just over the oil pan. Well, the fuel tank is in the belly of my 1989 maxum 20' and the ice must have gotten around the fuel tank which is alumunium and it must have caused a leak. Now here's my question, how do you fix this? It looked to be a seam around this tank. Do I score around this? How is this fastened - nail /screw - and then pull this section up? Any input would be appreciated! Thanks.
