help for a rookie installing another battery
iluvsailing
Hello, guys, so I just finished putting a radio in a friends boat now he wants me to help install another battery, it?s a 21 Contender with a Quest 16061 battery charger, I know im going to need to get a new master switch, but that?s it I put one more battery holder in then just run it to the switch and that?s it? but what about the charger can it do 2 batteries?
Any help would be greatly appreciated, thanks in advance
mthieme
Re: help for a rookie installing another battery
You'll need a Perko switch.
Charging both batteries is not an issue.
Back feeding the alternator is.
This question comes up frequently.
If you do a search on the posts, you will find more info than you need - including detailed wiring diagrams.
tashasdaddy
thank Silvertip for this diagram
Tanz
Here are diagrams and install instructions for Battery Selectors and Disconnect Switches.
Go to http://www.colehersee.com/resource/index.htm
Scroll down to -Battery-Related Products-
Then click on -M-750 Series Master Disconnect Switch wiring
-Just in case everything goes wrong for you. On this page are all the insructions on how to rewire just about everything else in your boat.
Tanz
The M-750 is a master disconnect switch -- it cannot be used as a "dual battery switch" which allows selection of BAT 1, BAT 2, BOTH or OFF (master disconnect).
