Help: Floor for 16ft 1977 Deep V Mirrocraft
Status
Not open for further replies.
Giacomo8690
Hello Iboaters! I am looking to install a Plywood floor with marine carpeting for my 16 foot Deep V Mirrocraft and was hoping I could find some good advice concerning design from you guys. I am unsure about how to design the floor for the best integrity and support. I have seen other aluminum boats with brackets installed d]wn center by original manufacturer for floor support however my Mirrocraft did not have that luxury. My other question concerned how to connect the floor to the boat. I have seen that some people have riveted the floor into ribs but I am not sure if that is the best option? I appreciate all your help and advice. Below please find photos for reference.
Giacomo8690
I do not think the previous post included the photo of my boat. Below please see the attachment!
Ayuh,.... Welcome Aboard,...... I hope you intend to put the center 2 seats back in,..??
Otherwise, the hull could fold up in two, from the lack of support,....
Giacomo8690
Hello Bondo,
I do not plan on putting the center two seats back in. I plan on sealing the holes made from the bolts for the center two seats with either 1/4 rivets or a larger bolt of some sort. The center two seats were never connected to a plywood floor, they were supported by bolts through drilled through the hull. I am seeking another way to support a plywood floor down the center of the boat.
jbcurt00
There were 3 bench seats, 1 set of brackets for the center bench were removed.
But yep, you're deck (floor) plan needs to include lateral support for the gunwales if you arent putting all 3 benches back in.
IMO, you should install a central stringer fore and aft if you intend to put a deck in. Otherwise you'll have to build a concave deck....
And I would keep the deck as low and close to the existing hull/ribs as possible. That should allow you to put the benches back in.
Dont forget to include flotation foam in your deck and bench planning.
Giacomo8690
Thanks for the advice guys! I really appreciate it! Unfortunately the boat was purchased with two benches only. You can see the support brackets for these two benches in the picture above. I removed both but still have them in hand. Regarding a central stringer, is it possible to construct one made of wood?
gm280
If you have plans to install a level floor and then a couple swivel fishing type seats, then I see no real problem. That being the floor supports and actual floor will offer the lateral support and maintain the hull integrity. But a quality subfloor support system will have to be installed first to accomplish that. I also thing I would fabricate aluminum subfloor supports and either good quality rivets or stainless steel hardware to install them. Then a good solid plywood floor equally attached with stainless steel hardware. Then floatation foam beneath the floor for both floatation and support... I can see that easily happening and being solid as well... JMHO!.
DinoW
Hello, I am in a similar situation and was wondering if anyone had a link with a simple floor plan. No background on this just looking to add a level floor, provide support and not add to much weight. Thanks in advance for anyone with any ideas. .
GA_Boater
Please start a thread of your own, This one as been inactive for more than three months. If you start a new topic, chances are you will get help much fast than tagging on to an old thread. Thanks.
Closed.
Status
