Re: Help Again
Any time you start a new thread, you need to identify your outboard, preferably with year and model number. Asking the volunteer helpers here to go hunt down some post you made months ago is not such a good idea.
Then, you need to describe the problem in detail. Where is water leaking on the outboard? You don't say. You say your father has pulled the "gearbox." Do you mean by that that he has removed the lower unit, as he would to replace the water pump impeller?
We're not there. We can't see the engine. We don't know where the water is leaking, so we can't offer much in the way of suggestions. We don't even know what part you're trying to remove.
Fill us in with the details.
