4runneradam
Thread starter- Joined
- May 7, 2007
- 203
If you read my last few posts, I had a problem with the #2 cylinder not firing. Traced it down to a bad output on the prestolite cd box. I got a replacement from Standard Magneto out in Chicago. Hooked it up, fired up the motor, and verified spark on all 3 cylinders. Took it out on the lake, and the boat would only run up to 28mph and had poor acceleration. Pulled it back out, and noticed that the bottom carb wasnt opening all the way. fooled with the control rod and stripped out the screws. Fast forward to this week. Got new speed nuts for the throttle rod, and lined up the carbs so they are all fully open on WOT. Pulled the spark plugs and noticed the #2 plug looked like it wasnt firing. Hooked it up to the ears and fired it up. #2 cylinder is not firing, again. Switched output wires to the coils and verified coil is working, but the same output on the CD box is dead again.
Do you think I have another bad box, and it's just a coincidence that it went out the same way, again? Or do you think I have a bad stator or trigger that is causing that output on the cd box to not fire?
I got a repair manual to troubleshoot the stator and trigger, but it tells me I need a meter that will read peak voltage, and that a standard multimeter will not do the job. I have a regular radioshack digital voltmeter. I cant afford to buy a $200 fluke meter just to run some tests on the boat.
I'm going to bring it home next weekend and pull the flywheel to visually inspect the stator and trigger. If I find nothing, I'm probably going to take it in the shop and spend a bunch of money and wait a few weeks to get it back. I really don't want to do that, but I don't know how to check it without buying a new meter, and even then it seems a bit confusing on how to test.
