Help. 68 Johnson super-seahorse slow.
Chrisice77
So, back in July I started a cheap restoration of a 1975 challenger 15' cathedral style hull and have since completed a full rebuild. Everything was great till we put her in the water and she maxed out at somewhere around 10-12 mph (gps). The motor is a 1968 Johnson 40 super-seahorse. I feel like this is exceptionally slow for a 700lb boat and 1-2 160lb guys with no gear. Tried everything I know of and can't get any more speed. Boat is recently sanded and painted so hull is clean and smooth, tried 3 different props 11 3/4" and 12" pitch, rebuilt carb and fuel pump, link and sync, timing and carb butterfly all operate properly, all new fuel (new gas, tanks, and lines), re-gapped and cleaned points and checked coils, new plugs and checked spark on both cylinders, compression at 92 and 93 on both cylinders (probably a bit low), adjusted high-speed and low-speed jets to factory spec then adjusted slightly to get max rpm's. Also tried every trim setting with no change in performance. She sounds fine and is probably somewhere in the 5k rpm range but just gets no power. The only flaw I found so far is just the compression being a bit low. Any one have any other ideas? Or could that just be the max speed I'm going to get on an old 40 horse?
Thanks for any assistance,
Chris
Chinewalker
Maybe try a lower pitch propeller. 12" is quite a bit for a rig pushing 1200 lbs. (boat, motor, guys, battery, gas tanks,etc.) Maybe find a 10 and see what happens.
Also, is the motor actually running on both cylinders? A cylinder drop test might be in order, even though you were guessing at your RPM, it is not uncommon for those Johnrude twins to 'sound' pretty good even when running on one pot.
Chrisice77
Thanks for the response. I'll try a new prop when I find one. For some reason I can only find like 11.5 - 12" pitch props on all my outboard similar to this size. To check spark on both cylinders we had it at near wot and my buddy pulled one plug boot at a time with noticable change in sounds both times so I'm relatively positive it's getting spark on both the whole time.
Tim Frank
Chris
Those engine-activated RPM sensors, (or ears as I call them), are notoriously inaccurate. :)
You need a tach that can give a proper RPM reading to know where you are....then you can figure out where you are going.
Chrisice77
I'm trying to figure that out too. Don't know if I have a bad tach or what, but regardless of the pulse setting it will only read between 200 and 1200 or so.
I'll work on the tach in the morning and let you know what I'm turning from there.
Thanks for the insight.
Chinewalker
A pulse tach likely won't work with a magneto ignition. I believe you'll need to use an inductive tachometer like a Tiny Tach to get a reading.
Chrisice77
The compression was between 92 and 95 on each cylinder for 3-4 times. I felt this was a bit low.. I just can't see 10 psi making such a huge difference.
Yeah I can't get the tach to work. I literally get the same readings on every pulse setting which clearly isn't the right reading.
Tim Frank
Did you strip the hull right down? No chance of a few hundred pounds of waterlogged foam?
Chrisice77
Hull was down to fiberglass shell. Replaced stringers, foam, floor, and transom. She's lighter than ever.
lindy46
Yeah, that's low. Compression should be 110psi or higher.
pro-crastinator
If you remove the cover and turn on the throttle, (while in gear - motor not running) can you see that the butterfly opens fully?
My thoughts are that IF the motor was "worked on" in the past (high probability) it is remotely possible that all the linkages were put back with less precision than they once had.. ... carb and magneto removal primary focus.
Me thinks there is a linkage wire that CAN be installed upside down that will keep butterfly valve from coming open fully.
I have been guilty of that in the past and symptoms were pretty much exactly what you described.
Just a thought.
Chrisice77
We have reworked the linkages multiple times. When I first got it nothing was working proper. Now the timing fully advances and the carb butterfly fully opens after timing is full advance at wot.
Chrisice77
That's the next step. I'm starting to think it's just underpowered. Have a Johnson 30 long shaft that I switched over yesterday and barely hit 10 mph on gps again.
pro-crastinator
Find a buddy with an aluminum 14 ft boat and strap on the Johnson and see how she runs.
How far did you tear into the tri hull? did you evacuate and replace the flotation under the floor?
Chrisice77
Gps is accurate. I even have the pitot tube for the boat speedo that registers the same.(not that they are and more accurate).
The boat is light. 3 guys can move it. 2 on the back and one on the front. So it's not like Ive got hidden weight somewhere.
I tore it down to nothing but fiberglass. Everything but the actual shell of the hull and deck were replaced.
Chrisice77
So I was talking to my boat mechanic the other day and he said these older motors were hp rated at the power head.. Which turns a 40 into a 28-30 at the prop from drivetrain loss... Anybody heard of that?
Chinewalker
Yes, but it's not quite that extreme. More of a 5-10% variance downward, so your old 40 might rate at about 35 today. I still think it ought to skip your tri-hull right along if it is as light as you say it is.
Just for grins - you aren't trying to run a short shaft motor on a long shaft transom, are you?
