Chrisice77
Thread starter- Joined
- Oct 13, 2015
- 10
So, back in July I started a cheap restoration of a 1975 challenger 15' cathedral style hull and have since completed a full rebuild. Everything was great till we put her in the water and she maxed out at somewhere around 10-12 mph (gps). The motor is a 1968 Johnson 40 super-seahorse. I feel like this is exceptionally slow for a 700lb boat and 1-2 160lb guys with no gear. Tried everything I know of and can't get any more speed. Boat is recently sanded and painted so hull is clean and smooth, tried 3 different props 11 3/4" and 12" pitch, rebuilt carb and fuel pump, link and sync, timing and carb butterfly all operate properly, all new fuel (new gas, tanks, and lines), re-gapped and cleaned points and checked coils, new plugs and checked spark on both cylinders, compression at 92 and 93 on both cylinders (probably a bit low), adjusted high-speed and low-speed jets to factory spec then adjusted slightly to get max rpm's. Also tried every trim setting with no change in performance. She sounds fine and is probably somewhere in the 5k rpm range but just gets no power. The only flaw I found so far is just the compression being a bit low. Any one have any other ideas? Or could that just be the max speed I'm going to get on an old 40 horse?
Thanks for any assistance,
Chris
Chris
