Help! 1976 Mark Twain restore it or junk it?!?
Lectro88
restoring a boat is not a way to get a return on your investment but than again neither is buying one. As stated by others boating is a hobby not a cheap one either. Restoring a boat is not about money, it is about pride of knowing you built it and you know it is more than likely the most solid boat that is around you at any point and time.
You Nailed It.
70marlin
I will be doing it by myself, I know that the motor was started every year for the last 4 years, but it hasn’t been in the water for 4 years.. and I don’t see and chips or cracks on the hull. I have a 5on-2off-2on-5off schedule so I will have some time to work on it. And I will hopefully test the motor this weekend and update this post! Thank you!
Stick in a barrel and see if it runs! Be for you spend a cent
