head bolt torque
fdhfdhaab
can someone tell me head bolt ft lbs for this engine ,95' 150 efi ser num.og200786 thnks!
woody66912
Re: head bolt torque
Start on the two center bolts and work in a clockwise pastern.
22 to 25 lbs.
Dukedog
25 ain't enough. Been a "hot" topic before. Best i've seen and use is three graduations up to 38/40 lbs final. Book and some use tha extra 90 degrees but i've seen too many block threads go south with this 90 degree stuff. But we remove heads ta check things a lot. I know tha 38 lbs will hold any stock motor out there cause some of our motors are well north of 200/230+ lbs.................JMO
BTW, think tha pattern is numbered on tha heads maybe..........
