Have to prime to start 25hp
fabweldcad1
New to site Hi everybody my problem is I have a johnson 25hp wont start when cold unless i remove a plug and pour some petrol in bore after running if i stop any longer than10 minutes have to put petrol in bore to restart runs fine apart from this. 1980's engine
JB
Re: Have to prime to start 25hp
Howdy, fab.
Welcome to iboats. :)
We need more info than just 25HP. Give us the model number and make.
What happens if you spray/squirt a bit of fuel into the carb throat?
fabweldcad1
model is J25BAC IM have not tried spraying fuel into carb throat.
beagleboy
How old is your gas in the fuel tank? Did you use gas from a container that has been sitting around? What I'm getting at is stale gas.......or as we have here in Canada seasonally adjusted gas. Possibly summer gas (contains no ethers for cold starting in cool or cold weather). Just a thought.
Are you using the choke/primer. Are you squeezing the primer bulb to fill the carbs? Is this an electric start motor? Is this a tiller steer or remote motor? Details, details, details.
