Harmonic balancer replacement
tbruenings3
1987 Bayliner 1950
OMC 3.0
Engine model 302AMFTC
serial T097525
How do I replace harmonic balancer (wobbly)?
Does engine need to come out? or temporarily propped up while front engine mount is removed?
If anyone knows the procedure I appreciate the advice.
Thanks
HT32BSX115
Re: Harmonic balancer replacement
1987 Bayliner 1950
OMC 3.0
serial T097525
Thanks
Howdy,
Welcome Aboard!
You can replace it by removing the drive, put a suitable block under the engine and the front engine mount (assuming you have room in front to get to the damper with a puller to remove it)
You can then either sent it to the Damper Doctor for rebuild or exchange, or just buy one if you can find the right one. (I like the rebuild because you KNOW it'll fit when it's rebuilt)
Then re-install it, adjust the alignment and re-install the drive. (If you don't have an OEM manual, you might want to obtain one)
Regards,
Rick
