coin operated
- Jul 30, 2009
- 35
My 50 hp 3 cyl runs great once it gets started, but starting it is really hard.The bulb pumps up hard, the enricher clicks, but it does not get enough fuel. I spray my fuel mix into it with a spraygun, and it fires right up. It usually idles fine, but every once in a while it will die at idle. I have removed and cleaned the carbs, including idle jets, new floats set correctly, new needles, new fuel lines from tank all the way to carbs, new fuel filter, and I have also put a new kit on the fuel pump. I am not sure what to try next. Any good ideas?
