Skidude17
- Jul 10, 2014
- 234
4.3mpi
Electronic ignition...Duh. I'm awake now.
4.3mpi
How do you tell if they're marine rated? Is there a specific vehicle you look under, or do you just go to anything with a 5.7L engine?
Yes, fuel injected. I'll get it right eventually. As for me, I'm still struggling with my dribbler:lol:Marine rated electrical equipment must carry a 'SAE-J1171' label. That is how you determine if it's 'marine'.
https://forums.iboats.com/forum/engi...omotive-engine
Chris...
And oh, this....
No, not yet.I stopped the dribbling carb by changing the complete engine, for a carbed with electronic ignition (4.3LX) to an injected (4.3MPI). All Mercruiser V6 and V8 engines have had electronic ignition since 1982. The inline 4s were phased in around the mid 80s. They experimented with distributorless ignitions, and EST. But now, even the humble '140'/3 litre engine is injected.
Rebuilding the Weber does not fix the dribble. I once had a Weber on the bench with the top off. I filled both sides with fuel. No dribble. I then blew air down one primary throttle barrel (with the throttle full open). I saw the fuel level in that side float chamber start dropping, and fuel being sprayed out of the bottom of the carb. I stopped blowing the air and refilled the float chamber to the same level as the other side. The venturi in that barrel continued to drip, and 2 hours later, that float chamber was empty.
The only conclusion I could reach on the reason was that the passages in the carb between the chambers and their venturis are so small as to allow fuel to be drawn up and to continue to make its way through the carb by 'capillary action'... When I suggested this to carburetor 'specialists', I get told that can not happen. When I tell them I saw it with my own eyes! they go very quiet!
Webers dribble, causing hard starting, and nothing can be done to fix them, short of putting a different carb on. End of story.
I did eventually fix my engine's dribble problem... See my signature.
Chris........
1. Yes.
2. Float drop should be 51mm (2") (Do you have the MERC factory manual?)
Chris........
vapor lock probably, if you have enough room you can buy a phenolic spacer in place of the paper thin carburetor gasket. probably 1/2" thick it isolates the carb from the hot manifold, not boil the fuel. In the future learn the boat, push throttle wide open crank engine when it catches pull back. You never sovle it completely. I had a 3.0 liter do it forever gave up just pushed throttle wide open.. in fact if was going to anchor i would push throttle wide open as soon as I shut engine off so when i was ready to go it would fire instantly. again carburetor suck but easy, fuel injection fire instantly but complex. i did it for 30 years with a boat. i admit i miss the smell of ether. also your starter should be cranking about 200 rpms. mine was only doing about 100 rpm's (under water a couple times lol) that really helps. if you have a compromised starter not turning engine over fast enough then your fighting a rising tide. truth be told once i got good starter didn't use ether to start engine anymore.....
wow glad you solved it. oh make sure you patent your carburetor it a perpetual machine, frictionless. It the only pump on planet that disperses gasoline with no external engergy input. Oh wait its sitting on the manifold and the heat from the engine is putting energy into the carburetor expanding the gasoline. gasket didn't work because it wasn't thick enough. once the engine is running its a venturi effect that pulls gas out of float boat. when starting its the accelerator pump that puts gas in to the carburetor. when sitting there unless you have a leaf blower going across the top you have no venturey effect and you have no accelerator pump you have heat from engine
... I find it hard if not impossible for there to be enough surface tension / capillary action to cause the dribbling.....
